As per title i have for sale a used 260 ECU
Part number is ALS3M0352F.
This ECU is for electronic throttle white dash cars. The code is from lotus and is the code used on the original 211 to up the power from 255 to 260 for the race series.
This ECU does not need the second lambda sensor so will run without a Cat, and not illuminate the Engine management light (211 Race cars had a cat bypass pipe)
I ran this ECU on my Exige before installing the Syvecs
No longer needed …
£350.00 inc the traction control switch (Plug in the switch before connecting the ECU and you will also have basic on/off traction) Includes mainland UK Delivery
Dave
07852680267
