Exhaust Volume?
I’m booked in at Bedford on the 13th Feb in the S1
The car came with the following fitted;
and has a standard one of these;
Can anyone advise as to whether it will pass the noise test or is it a case of hiring a noise meter?
Make a visit to your closest track day and ask them nicely to test your car, i wouldn’t travel to Bedford with out knowing because if it fails it’s game over.
Mike
Even if that Janspeed box was brand new,I think you’d struggle, Harvey.
Any suggestions as to what would be a good alternative but still has some ‘charater’
Been there… done that!!!
So has Mr Lotus Gray!
Suggest:
1: An EliseParts 6 inch silenced CRP running infront of the (VERY HEAVY!) Janspeed…
2: As above, but with an ‘Edwards’ custom made back box as per what the HOnda SC guys are using (Rob and Martin plus I am sure other rice burner guys). The afore mentioned LG had one fitted to his 220 BHP VHPD and it is bloody good (quiet!)
3: Dont go to Bedford!!! Unless you are in an electric car! They are SO strict about the noise stuff! BTW, when asked to set, 80% of your max RPM, that will be about 3,500 RPM!!! :smiley:
Harvey
Contact Martin @ www.lotuspower.co.uk
Cheers for the advice guys.
Been to Bedford in the Exige S many times and never had to worry about the noise - hey ho.
I’m one of the SC ricers running Martin’s exhaust and his massive back box.
I went to Bedford a couple of times last year and expected problems but did not have any. It was wet on both occasions but if you’re going in mid-Feb…
Cheers Ben - Email sent to Martin.
