Does anyone here know of somewhere where I can get my Emerald map tuned in the Midlands, to knock off a couple of degrees of ignition advance… my engine is still pinking under load at lowish RPM?
My laptop with VISTA is incompatable with Dave Walkers software… it won’t ‘talk’ to the ECU despite loading the Emerald software!
Yeah no worries mate. Where are you? If you can get your car to me, then I can make what ever adjustments you want.
If you want to do it on a rolling road, so we can get it spot on, I have that facility as well.
Give me a call on 07967 662294
Sean
Excellent Sean… Many thanks!
I am near Worcester… where are you please???
Since it is just timing causing the pinking (I hope??) I reckon just a few degrees of retard should do the job? If not it might be an air leak somewhere???
