Emerald MAP
Does anybody have an Emerald MAP for a VHPD engine (S1 Exige) running a LOTUS 190 coversion without aircon
Thanks
Simon
Have you fitted verniers and retimed the cams.
If you have then I have an excellent map, otherwise no.
If you havn’t fitted the verniers, I would do so as its makes a big difference, the standard cam timing is shite, even with the so called modified pulley that comes in the 190 kit.
Yep I have fitted verniers I will PM you with my email address
Thanks
Map sent.
no map
Sorry, hopefully got it right the second time.
I’ve got it heading into the garage to try could be a late night
Thanks
Simon
Good luck
