Hello
When I turn my over run fueling on my car seems to run very rich. Any chance someone can post there O load site in the injector chart so I can compare it to mine?
Here is mine
[image]http://www.rs-turbo.co.uk/fuel.jpg[/image]
Thanks
James
Hello
Here is mine
Thanks
James
It may not be representative, regulator pressures and engine tune change all.
But I didn’t understand the problem anyway…
Turning the overrun fuelling on or off should make little or no difference to the main part of your running since it only comes into play on a closing throttle. The load site zero values are irrrelevant to this particular function and comparison of injetor values will yield little useful info.
Maybe you should have a word with Karl at Emerald to find out what your real symptoms are, he can problably sort it out for you in 5 minutes flat.
Dave
