Has anyone else had this problem. It happened a while back that the window was approximately 1 inch short of fully shutting and i had to pull it up manually which almost brought tears to my eyes. Problem is, while it was fine for a couple of months, it now seems to be doing it all the time.
I realise the chances are this problem has been caused by some idiot passenger using the window for leverage when they have been getting out of the car . Does anybody know if this is an easy fix or is it going to become a bigger problem if I leave it and eventually break the electric window motor?
Might be the top fixing screw on the front guide rail has come loose. Drive the window down and look forward between the rubber bits, might need a torch, you should see the guide rail and the top fixing, usually a posidrive screw. Check this is fully tight. HTH
This is probably it, and it takes one minute to fix. Just tighten the screw. Happens all the time.
