Hello,
I’m looking for input on what an aprox. 220hp spec motor built by Dave Andrews would be worth It cost about 9K pounds to build. I’m thinking of putting it on e-bay and was looking for input as to what it’s worth before I go to the trouble. It comes with an Emerald, EBD big bore manifold and a complete exhaust system (eliseparts). In the input side, it has the Scouse airbox, trunking and filter.
It has 0 Miles on it, never started.
Thanks
Roy
ps. Here’s the specs that Dave sent me when I paid him:
Item
Good secondhand VVC block
2nd hand and new bits and bobs (water pump, pulleys, cam belt cover, oil filter housing ,sump, pickup,
new cam cover, crank pulley and bolt , new water elbow with senders etc.
Secondhand cam belt tensioner
Throttle potentiometer
Set of Omega pistons
Set of german liners
VP2 competition lead/bronze indium bearings
Main bearings
Thrust washers
Oil pump
Steel oil pump rotor
Steel flywheel
Flywheel bolts
AP clutch
Bottom end gasket set
Full engine balance
Machine pistons crowns to clear larger inlet and exhaust valves
Machine block to set liner heights
port pump and fit steel rotor
Head
2002 TF160 VVC head complete less VVC mechs
Allowance for old valves and followers sold on your behalf
Pair Piper VVC 1227 cams
Piper VVC blanking kit
Pair Piper verniers
Set Piper double springs
Set Piper steel caps
Set REC 214N 32.5mm inlet valves
Set REC 214N 28.3mm exhaust valves
Set Colsibro bronze guides
Set Piper solid followers
Set of solid follower shims to suit
Port head for 32.5/28.3mm valves, machine clearance for cam lobes
Remove old guides, taper and fit new guides and recut seats
Shim cams
Assemble head including VVC blanking kit
Match TBs to head, fit spout, modify linkage and assemble to head
Skim head
Head gasket set
Head through bolts
Cam ladder and sump sealant
Bolts and other fastenings
Set Platinum plugs
Jenvey Direct to head TB kit
Bernard Scouse airbox kit
EBD Ultrabore exhaust manifold
Emerald ECU
Mems connector for adapting Exige loom
Fully assemble bottom end of engine, fit head, time cams etc.
