My left hand front brake is dragging… car wont roll forward on a slight downslope and the wheel does not spin freely.
Also, under heavy braking, it locks up WAY before the others!
OK guys… How do I fix this problem please?
Take off + dismantle… Free up sticking parts + copaslip any metal/metal sliding parts…(including pad to caliper touching area)
If the pistons themselves are sticking then its time to overhaul or renew the caliper …
Ps Ive found that diy piston kits don’t work …
If the caliper is sticky 2nd hand are easy to source and cheap
WD40
[quote=Mr Pesky][quote=pete757]
WD40 [/quote]
Sprayed liberally on the offending disc should cure ALL unwanted stopping tendancies !!!
[quote=jfk][quote=Mr Pesky][quote=pete757]
WD40 [/quote]
LMFAO!!!
JSRacing have loads of the 2 pot callipers in stock, brand new. �100 each if i recall
