Has anyone had to rebond the door glass back into the 3 plastic mouldings supporting it?
If so, did you bond the glass outside of the door, then feeding the assy through the letter box, bolting to the mech
Or leave the mouldings bolted to the window mech and bond the glass in place inside the door?
The forward moulding seems very awkward to access
Want to sort this out over the weekend, so appreciate any feedback
Andy
From memory I bonded the glass in the door. Like you say it looked an easier job. I used 5 min apoxy and have not had a problem since.
I did my Elise with the glass in the door, all assembled in the correct position. I think i used a good bead of bathroom sealant along the bar which holds the glass. That was four years ago, fine ever since.
Thanks lads!!
