I currently have harnesses and they look great but I’m finding them a faff every time I get in/out and trying to reach anything from the dash, seat, footwell etc, so contemplating swapping back to seat belts.
I don’t track the car.
Are they considering safer than harnesses?
Harnesses really restrict you leaning forward at tricky junctions to see. Properly set harnesses should be very tight and ideally and ideally have a crotch strap. Also, 3 points tend to turn you into the empty middle of the car on impact.
Harnesses are illegal for road use in many countries, with good reason.
I have both in my S1 but only use the harnesses on track.
Agree with the consensus. Don’t have three point mounts in the 2-Eleven so forced into harnesses.
The only thing I’d add is that I really wasn’t a fan of the bolt kit to let you run both harness and belts at once for my Exige. The Lotus seat mounting is sketchy enough as it is, and adding that great big long bolt in single shear made me put it away in the drawer and never look at it again.
