Anyone fitted the rear diffuser lowering spacers from eliseparts? wanted to know if they are worth having or not…
I’ve fitted a set to the Elise and think that the boot is now cooler than it was before.
Could just be that I want it to be, though, to justify the cost
I think they only do them in black now, even though the website shows silver.
They’re quite expensive. Can you not make something yourself that’ll do a similar job?
I use the little circles that I cut out of the rear clam to help with hot air extraction…
This supplied about 20 laser blue ‘washers’ of varying thickness
Made up my own 15mm spacers from Broomhandle drilled and painted black…longer SS bolts from fastener supplier …saved �30.00
MrsP was wondering where her transport had gone
cheers guys
Rob at least it is a “K” type broomstick.
