So got the shaft out easily enough, bit of leverage here and there.
CV dropped off without me touching it, the boot inside was dry and filled with metal flakes, chunks of cage, and balls. Sadly it seems it’s also shafted the shaft:
So need to figure out what the Lotus Spline specs are (on a S2 Rover outer) and get a new one made up (this one is 397mm end to end)
So got my new Lotus OE outer, and stripped down the whole assembly.
The tripod had three witness marks in the bottom of the cup, and looking at the shine on the races I’d say the joint is only really using the bottom half off the cup so I could and should get a slightly shorter shaft.
Handy enough, Dan websters shafts are a little shorter so might buy one from him.
OK new shaft ordered up from DJM crafted from S155, also have two new Lotus Boots and also scored three (one as a spare) of the AMK TSB50 boots for the inner, they’re smaller so less chance of hitting things.
I believe Andy guided me at Motul Tech 300 as the best for the inner end. Neo stuff is apparently too thick to get right on to the rollers. It’s much cheaper.
