Two things - where is the best place to buy a decat pipe from? I had emailed larini to order but never got a reply but was wondering if it was the best bet?
Second, I noticed yesterday that no matter where the dial is for the air direction (windows, feet etc) it always comes out only the window vents. Is this a cable issue or something up with the switch? It worked fine before but now doesnt.
Piper do cat pipes but they are to suit there own special manifolds. They come in either striaght thru, silenced CRP or race cat. The whole kit incl silenser is �870 with straight thru, �890(?) with silencer or �990 with race cat (all excl VAT) so its a bit pricey but a good allround solution.
The heater distribution control is done by a cable (as is the temp). To get the the input end you have to remove most of the dash (so its not going to be that end!). To get to the output end you take off the front left access panel and you’ll see you end under the wiper motor. Its probably just slipping in its clamp. You’ll probably need to remove the wiper motor assy to actually get to it but you should be able to see it with the motor in place.
