Have you even been out for a drive ( not within the last two days ) and you have removed the key but the dash reilluminated with the miles et al on display?
How did you fix it?
How did you fix it?
Fixed it!
There are two fuses in a cluster near the ECU. One fuse is for the immo.
Removed that , gave it a magic rub and reseated all the fuses.
Works perfectly now.
Result! Good work
Handy lads, you lot! I tried and failed to fix a neighbour’s lawnmower today.
I have two tools in my tool box.
I applied a socket to a nut securing the mower cutting blade and failed to shift it. I had to tell my single mum neighbour she needed “a new flange”
I await developments
Snigger.
I bet that was fun.
Flange is such a brilliant word.
Almost as good as “ moist”
