cutting out....?
i don’t know if anyone has had this problem… but when driven hard on a left hand turn sometimes my car starts to miss fire…-it feels a bit like the rev limiter is kicking in even though the engine is at full temp!
Turn Of Tracktion Control
Could it be tha cam dropping back down to the lower profile due to lack of oil pressure?
Gav
It must be fuel starvation.
Try again with full tank of gas.
I Use Petrol In Mine
However i think it leaks oout as i keep having to top it up every few miles
Does your car have a wheel speed sensor (not sure, only going on K-series experience)? If so then it could be disconnected/have a loose wire/on it’s way out.
must admit i once nearly ran it out of petrol and it did the same thing! hope i have not buggered it up!!! blocked the filter in the tank or something
