custom intercooler
posting for ronin.
[image]http://www.moremonkey.com/forum/files/chill_139.jpg[/image]
charge temperature fullboost drops between 85 and 95 degrees F, keeping it a maximum of 15F above ambient at the intake.
Thats interesting…tell me more, or where i can find out more info.
This sucker is in Lotus own words 3.7 times more eficient than an air to air intercooler of the same size.Even if the Air/air is getting direct flow…more info can be found on www.moremonkey.com
could you be a bit more specific…i am having trouble finding it there, thanks.
Look under supercharging a Elise/Exige…or just look at the NSFW under stuff…
Looks like a neat install. I’ve had a quick look at your site but I can’t see where are you getting the cold water feed from? Have you installed a secondary radiator in the nose, like the Bemani setup?
6"“x 26” x 1 1/2" heat exchanger mounted verticle in the nose so that it gets direct airflow …Water temps for the engine are not affected…just takes a little thought.
