Crunching into reverse when hot
As per the title, 2006 Exige S - cant select reverse once its hot. I’ve changed the slave cylinder, but that hasn’t made any difference. Any ideas? Worth changing the gearbox oil? Any thoughts / ideas greatfully received.
Thanks.
Cable can stretch a little when they get warm, might be worth adjusting first or replacing if it’s old and worn .
How do you adjust the. Cables?
