If I’m blowing some cobwebs away by taking the revs over 6k then when I change up into 5th it always crunches. Doesn’t happen at lower revs. Very annoying at the moment as I get some decent momentum going only to loose it all struggling into 5th without wrecking the box.
I have had the gear change linkages and bits adjusted. The restraining bolt under the gearstick isn’t the problem either.
I’m assuming something is wrong inside the box. Any pointers before I take it back to the dealer under the warranty?
Don’t know, the same happens to me but only sometimes from 3 to 4.
I was blaming it in doing the shift too quick, as it doesn’t wnhen I take just slightly longer.
Was going to have a word with Quaife thinking I was just shifting too quick and needed some straight cut gears instead…
Mine has always crunched into 5th … I adjusted the linkage to stop it and then it crunched into 2nd … so I decided 5th was a better “crunching” gear for mostly track use
