What are the benifits to knife edging and lightening the 2zz crank? Overall with a full engine rebuild, valves, cams, springs, pistons, rods etc what will it do performance wise? The std crank from what I’ve read seems more than up to the job in terms of safety so before I splash out I thought I’d ask you bunch of brainy tossers lol
This is another mine field, reducing weight is a good thing for a crank, less rotational mass has a similar affect to a light weight flywheel, knife edging is suggested to help it cut through the air easier, I’m not convinced it would make a big enough difference to mortals like us Merc in F1 it probably does?
It is definitely a case of diminishing returns. The most important thing with a crank is that it is balanced properly not only to itself, but in relation to the pistons and rods you are using.
You know my opinion mate. Stop F**king around trying to polish your turd of an NA and simply stick a super charger on it and go fast. The end.
Ok, so the crank is up to the job as is, lighter and knife edged may improve performance but would it help as well as fitting a baffled sump and accusump reduce the chances of oil starvation.
[quote=SeanB]It is definitely a case of diminishing returns. The most important thing with a crank is that it is balanced properly not only to itself, but in relation to the pistons and rods you are using.
Instead of messing with a supercharger why not have John build an Audi lump = Lots of power and no broken gearboxes - Job done.
Not worth the effort or money and there was nothing gained on the dyno…
I have a new stock balanced crank in the engine now…
Unless you are looking to buzz 10k and hold it there stay stock… No one has ever broken a stock crank that I know of.
[quote=seriouslylotus][quote=SeanB]It is definitely a case of diminishing returns. The most important thing with a crank is that it is balanced properly not only to itself, but in relation to the pistons and rods you are using.
