Hi Again
To see the importance of the length of the con rod crank pin, just give an example.
If you take a toothpick at the ends and apply a continual downward force in the center, will reach the point at which the toothpick is broken, if we do this in a toothpick smaller length and apply the same force, you will see that no breaks and you must apply superior force to break it.
Another question in the design of the crank is the lubrication system.
In this crank 2.0 serie k the lubrication system has been redesigned and improved, connecting every the oil step each other and not are independent as in the original design of the crank rover k series.
Connecting every oil step each other, you get the advantage of increasing the pressure of oil and also if the oil carril is obstructed in any place, the oil moves from one extreme to another, not leaving any crank and con rod bearing without oil.
Finally we can talk of counterweights.
The shape of the counterweights is very important, most of the crank are square with rounded corners.
In my crank 2.0 k series, the counterweights ending in arrow, and because when they come into contact with oil penetrates without hitting, reducing the brake exercised when striking oil in the crank and increasing the speed to take the revs and the oil temperature down at about 10/15 degrees.
The crank with the counterweights made diagonally, are dangerous, because there is an irregular movement in the oil sump, next to that movement of the car, you can leave without oil some point and cause breakage.
Regards
Vicente
