As above…is anyone running them?
Some details here http://www.monkeywrenchracing.com/product_info.php?cPath=21_23&products_id=1565
Look to compatible with std bores too.
I am considering these for my rebuild, but they are a bit expensive sadly
…but then you dont need darton liners - cost saving there?
To be fair, droop in the ocean to what I’ve spent recently :s. I do quite fancy owning an Exige GT3 thats powered by Cosworth though lol.
drooping in the Ocean has been a problem for me in the past too.
Radium sell them too:
http://store.radiumauto.com/index.php?p=product&id=68&parent=2
I get lots of emails from Nigeria offering me a solution to this sort of ’ problem’
To be fair, droop in the ocean to what I’ve spent recently :s. I do quite fancy owning an Exige GT3 thats powered by Cosworth though lol. [/quote]
Only any good if the bores are ok, which unless you buy a new block they normally aren’t
We have used them but at circa �600 they are quite a bit more than the Wiseco ones we normally use for fast road engines. We usually keep a set of each in stock though.
[quote=trackclub]We have used them but at circa �600 they are quite a bit more than the Wiseco ones we normally use for fast road engines. We usually keep a set of each in stock though.
What other engine parts do you stock, I need a few bits
Pretty much anything including replacement engines on the shelf in various specifications.
We are waiting for the next batch of valves to be delivered so we only have OE valves at the moment as opposed to our own spec, I think we only have standard cranks left in stock as well but most other bits are probably available.
Drop me a note with what you need
