Just done a cold compression test (I know it’s more relevant and important hot but gotta go out so may do it when I get back), and my car has had a hard life and will contineue to do so.
Current at 26000 miles it reads:
Cylinder 1: 14.8 bar
Cylinder 2: 14.6 bar
Cylinder 3: 14.5 bar
Cylinder 4: 14.6 bar
I’m pretty happy with that as at least they’re all even
How did you stop fuel injection - pull the injector connections off ??
I didn’t bother Just had all the plugs out and the leads off, also unplugged the coil pack (little 3 wire plug near the expansion bottle). There’s so little fuel to worry about really and any excess is just blown out the top on the compression stroke.
Thinking about it the box didn’t mention disconnecting fueling so you may need it to get a accurate compression figure as the fuel will add to that surely? shrug
Ahhhh thats the difference between a wet & dry test, to check it correctly, you do it dry, i.e. no fuel or oil.
Than take the readings, next add a teaspoon full of oil down the spark plug hole and retake the readings again.
This will shown you if you have any leakage past the rings as the oil will mask that and give a higher reading the second time round, the same goes for having fuel in there aswell, it will mask readings.
mark,
Its a guage you screw into the spark plug hole at tdc and then supply a constant amount of air pressure into it via a regulator, but you do need a air compressor to use one.
The guage will then measure the amount of air being lost either by the valve seat seals or past the rings.
It can also check if the hg is leaking.
I cant remember exactly how much mine cost but i think it was in the region of �50.
