Tried to get a replacement coil pack today, Bosch Number 0221503001, after I tried my local parts supplier he pointed me towards the Bosch dealer who wanted �330+vat
Elise parts cannot supply as they dont have a supplier
I think I could use the equilvent Opal 90443900 or 90449572 from a Vectra ?
Just about any 3 pin coilpack will do the job, but as stated the Calibra/Cavalier/Vectra is ideal. A quick trip to a local scrapyard may turn one up in good order.
Tis none of those unfortunately. The VHPD uses a coilpack with a single ECU input and 4 high tension terminal outputs.
Geary has been a bit optimistic with his compatibility list…
Some VHPD engines were built with a single coil and a distributor cap, later post 2000 ones were wasted spark/twin coilpack.
Dave
so we should be able to narrow it down to a chassis number or at least a batch…of course being Lotus there will always be a few exceptions to the rule!
I posted up somewhere (search coilpack or coil pack) some details… but there is an Alfa Romeo/Fiat aftermarket part that you can get for about �40-�50 and it works a treat.
'Calibra coil-pack is more expensive than the lotus one.
Motaquip VCL625 does the job but you need to switch plug leads 2 with 1 and 3 with 4 to make it work - because the LT plug is connected the wrong way round for us… cost me �41 for one in April… but the really good thing is you will get one from ANY motorfactor. Comes from a Punto or Alfa 1.8 i think.’
If anyone is looking for a “Lotus” one, a chap on the 340R group has posed that he’s just got one from Paul Matty in Bromsgrove (off the shelf) for @ �100.
Just converted mine to run on a Ford coil pack, Availaible everywhere, brand new for �18 and it gives a bigger bang for ya buck, with a quicker recharge time. Its a three wire coil, but the plug is different, but very easy to change over to the ford plug.
Yeah Steve straight swap and the mounting bracket fits too. The plug is actually really easy to swap over as well. I do have the Ford part number that you can quote to any motor factor and get the Ford coil for 2 and 6!!!
