So the clutch was fooked and since the engine is out we were thinking it would be changed anyway.
So is the best option to stick to OEM or go for Exedy stage1???
For a SC+CC Honda.
For a SC+CC Honda.
Exedy
have a chat with John mate.
Thanks will do…
exedy have differing US and UK models I’m told
OE seem fine for under 350?
What did you do for a clutch in the end Ben? The standard one I took off my car last year when we fitted the sequential gearbox still looked really good after nearly 5 years of hard use. Hardly any full bore standing starts though.
And yes, as above, you have to get the Exedy stage 1’s from the US otherwise you get something different which isn’t as good, even though it’s supposedly the same part.
Went for OE in the end Jamie.
Seems that there’s been enough people with similar power running fine on OE.
Also, I imported some injectors for the build and it took an age what with dicking around with customs, paying duty . I did not want to be held up with that as it would have to an import of the US version.
got the fiveo ones in the end?
Yup I followed your lead and got the same ones. They had the wrong adapters though as mine had been changed over to RC fit ones,…Matt sorted it out though.
ah right, someone had made you loom EV1, sure he just cut the splice point and grafted the EV14 pigtails on
