Well having changed my Brake master cylinder last year now I need to change the clutch one - fluid leaking down back of pedal …
Is it a dealer only part ?
just done mine about 6 weeks ago. yes it is a dealer part
i tryed to get one from else where but no luck
Dont Classic Brakes stock the seals Tony? Classic Brakes
They sorted me out with a rear caliper seal kit for next to nowt???
i tryed to get one from else where but no luckDont Classic Brakes stock the seals Tony? > Classic Brakes >
no i phone them and they only do brakes
poo!
So …
Clutch master cylinder 95 quid …
And … you when you get it out of the box it looks like you got the wrong one as a rod is already attached … when the one you took off doesnt have one
So … you have to remove the inside circlip and remove the washer holding the rod, remove rod and place back the washer ( the other way around from how it was installed ) and put back the circlip and dustcap …
Oh - when you remove the circlip hold on to the rod because the spring shoots the piston out
Simple really, just a shame for 95 quid Lotus didnt supply it like that …
