Does anyone know the bore size of the clutch master cylinder on a 2006 or newer Exige/Elise?
Thanks
Thanks
Is it the same as on the S1?
I am not sure… it is a different part number… the Lotus part number for mine is A120Q0007H
Isn’t it 7/8 vs the 3/4 of a s1
I could measure mine tomorrow that’s all…
After more research I dug up the one’s on both a Matrix and a Celica… and they were the same part number… and was able to find out that it is 5/8" bore.
I am assuming of course that ours is the same…
Jonny, if you have one lying around and could measure to confirm, that would be great… Thanks.
Will do, just left work for the weekend but will get someone to measure it tomorrow.
I’ve been told 19mm… Not at work to check myself til Monday.
sorry misread that as brake, oops
