Anyone no if you can use Secondhand clocks in a 2007 reg exige s? The guys at lotus told me you cant cos each car is set to its own ones, so i need to buy new ones. Is he just telling me a line?
Cheers guys
Cheers guys
You can if it is a white dial model, not sure on the black dial cars.
You should be able to as long as they are the same set of clocks. I had my 2-11 converted from the white to the black and they used a second hand set of black clocks for the job.
Ps I have a couple of sets of white clocks here I dont need so if you after a set…
Ta.
Gav
Thanks for that gav, do you no the mileage on them? And how much you want for them? John at jsraceing has got a set that I can try before before i buy, just waiting to hear back from him. Also mine has got the traction control? Dont no if that makes a difference.
Put my secondhand clocks in today and they work a treat. Let the good times role.
