Does anyone remember when Clarkson tested the S2 elise and he didnt like it because it understeered ? I think they then got the chassis bloke from Lotus to show hows it done, what was the difference in driver style ? I have an S2 Elise and when you really push on the front understeers. Oh yeah, its an SC Honda so any ideas welcome and comments on the above.
There are a lot of things that effect the handling balance -
Geo
ride height
spring rates
LSD
dampers
tyre size and compound
plus the driver - fast in slow out/ slow in fast out etc etc
Most Lotus’ cars have a decent handling balance although they rightly engineer in a safe bit of understeer which is nice to have on road at least.
I did have an Exige that was prone to understeer - due to the LSD so I worked on tyre pressure spring rates and damping to remove some of the excess.
As they say a race car with a hint of understeer is a fast race car…
Do you have Nitrons? spring rates? when was the last time you had geo done also what tyres are you running?
If you are in doubt take it to someone who knows what they are doing - Plans , Hofmanns etc etc
Just as an example went to a Lotus Exige day at Knock Hill Lotus brought along a 240R for peeps which already had an Exige (tempt them into buying a supercharger) and a n/a Exige. I drove both and they were very different the 240R had a little bit of understeer but very steerable on the throttle while they had made the standard Exige very understeery to give an extra safety margin. The Lotus guy did confirm they had played with the geo on the standard car to make it safe on a very wet track.
Obvious question then … I have had a full geo at Blink and have nitrons, motorsport arb, etc and I will find out tomorrow if all is well. If it isnt, what else can I do ? I believe the S2s cant get enough camber on the front, is there a way round this ?
That looks great and just like mine. Two questions, where can I get that rear wing and front splitter ? The splitter and wing should help, shouldnt they ?
Re front camber. If you lower the ride height it helps in getting more camber. I saw about 1.2 degrees when lowering the front to 105mm, and removing all the shims. To get more than that you have at least 3 options.
machine the steering arms. Relatively easy to do as there is quite a lot of excess material. This is deirectly equivalent to removing even more shims.
Get the eliseparts adjustable bump steer steering arms as these are already setup to allow more camber
Consider changing the uprights to the eliseparts versions or have the existing uprights machined.
I’ve gone for option 2) and running with 1.5 degrees camber. Had to put shims back in to set it to this.
Makes the car tramline quite a bit on the road but turns in well on track, although still get a bit of high speed understeer. Still experimenting.
My old exige s1 (post blink geo) was perfect, and I really do mean perfect on track. Never even a hint of understeer and this was with the original lotus suspension. Awesome it was.
I wonder though if my SC Honda S2 Elise is just carrying a lot more speed than my old VHPD steed …
Well its my first trackday in the elise tomorrow and I hope its a lot better than on the road, I am secretly hoping its just the 48s not getting up to temp.
