Howdy
Are there any people who have tried to fit children into the seats of an exige?
My son (nearly 6) wants to come with me to collect the car (S2) but I’m not sure if that would be wise…
so some questions if any of you have tried to strap a child into the exige…
do they fit?
can they see out?
I pressume harnesses are a no no and just three point ordinary belts?
do they need booster seats?
do they make a mess?
do they scream at high speeds?
cheers
Adrian
Summary of the Seat Belt Laws for Cars, Taxis and Private Hire Cars
Child Under 3 Years of Age - Appropriate child restraint must be worn.
Child Aged 3 to 11 and under 1.5 metres (about 5 feet) in height Appropriate child restraint must be worn if available. If not, an adult seat belt must be worn.
Child Aged 12 or 13 or younger child 1.5 metres or more in height Adult seat belt must be worn if available.
Passengers over the age of 14 years Adult seat belt must be worn if available.
An appropriate child restraint is one which:
conforms to the United Nations standard, ECE Regulation 44-03
is suitable for the child’s weight and size
is correctly fitted according to the manufacturer’s instructions.
Child restraints are divided into categories, according to the weight of the children for whom they are suitable. These correspond broadly to different age groups, but it is the weight of the child that is most important when deciding what type of child restraint to use.
Retailers often describe child restraints in terms of ‘Stages’:
Stage 1 = Groups 0 and 0+
Stage 2 = Group 1
Stage 3 = Group 2
Stage 4 = Group 3
Some child restraints are capable of being converted as the child grows and, therefore, fit into more than one group or stage.
The main types are:
Rearward-facing Baby Seats
Group 0 for babies up to 10 kgs (22 lbs) roughly from birth to 6-9 months, or
Group 0+ for babies up to 13kg (29lbs) roughly from birth to 12-15 months
Forward-facing child seat
Group 1 for children weighing 9-18 kgs (20-40 lbs) roughly from 9 months - 4 years.
Booster seat
Group 2 for children weighing 15 - 25 kgs (33 - 55 lbs) roughly 4 to 6 years.
Booster Cushion
Group 3: for children weighing 22 - 36 kgs (48 - 79 lbs) roughly from 6 - 11 years.
Legal Penalties
If you are convicted of failing to wear a seat belt as a driver or passenger, you could face a fine of up to �1,000.
As a driver, if you are convicted of failing to ensure that a child passenger is using an appropriate child restraint or wearing a seat belt according to the legal requirements described above, you could face a fine of up to �1,000.
In addition to the legal penalties, failure to wear a seat belt or failure to ensure that a child passenger uses an appropriate child restraint or wears a seat belt according to the legal requirements described above, could affect any claims against your motor insurance cover.
You could also face civil proceedings for damages, if (for example) you failed to safely carry someone else’s child.
