Cheap AP 315mm 190PCD
Lotus clearing them
One side: http://www.motorsportauctions.com/category/420/Suspension-and-Brakes/listings/34014/AP-Grooved-Brake-Disc-Number-CP3580-1097G8.html
Other: http://www.motorsportauctions.com/category/420/Suspension-and-Brakes/listings/34013/AP-Grooved-Brake-Disc-Number-CP3580-1096G8.html
They do have bells (with no bobbins) and a bias pedal box (no MCs) but both are more than buying elsewhere, like our man Dave.
T
Correct, but those discs are not expensive and are the correct size to bolt directly to the cup260 bells. An ideal upgrade (315mm discs)
Cheers for the clarification,
Still 100% better off on Dave’s bells though, as lotus want £215 (once vat added) a side and it’s missing the £70 bobbin kits, so £570 all up.
Ah ha missed that bit, Thank you!!!
Floating bell kit here http://www.seriouslylotus.com/braking/brake-misc-other/seriously-lotus-fully-floating-disc-bells-pair-s2-ap-discs
Or fixed bells here http://www.seriouslylotus.com/s2-alloy-disc-bells-to-suit-ap-308-discs
Well that just cost me a fortune…
Tim
Have your discs turned up yet? Mine haven’t :frowning:
Nope!
They sent me the invoice though, odd
Don’t worry guys
Claim back from your credit cards… then go here
100% in stock now with next working day delivery…See you at Anglesey…Hopefully
Scratch that, they turned up Friday just Mrs muu had put them under the stairs
got mine Lotus forgot to post them…
fitted one side already, small amount of fettling of the calliper and an extra washer and the back is perfect,
front needed 2 washers and nothing else.
I might even have a handbrake that works for the first time in 2 years LOL
So you’ve gone 315 all round?
How’d the oe2 pots fair up? Must be mighty close at the edges?
Yep, 315 all round,
Just needed to fettle the 2 pots a little to make the fit better, I probably will get the correct callipers later, they fitted straight into the handbrake callipers just fine
