I’m in need of a set of centre caps for the S2 Y spoke wheels, flush fitting kind, is there a reasonable aftermarket source?
If you mean the under noted Y type forged wheels you need to bear in mind the centre caps are the 'thin" 60mm x 10mm items. I needed to replace two as the plastic fitting lugs had snapped.
DeRoure supplied new caps @ £5.07 each - part no. A12G0013F. These will be yellow / green logo. Alternatively, if you need new self adhesive logos I used Signdezine who supplied black 3D domed gel resin centre cap stickers (size 60mm). They were much better quality than the OEM logos which peel off after the cap has been heated with a hair dryer.
If the purists wish to lead me outside for execution … may I have a blindfold.
Hope this helps
IIRC the type as shown above is the same as used on the Evora, so a current part.
Nice fishing tackle btw
Trickster on seloc provides great quality black/silver centre-caps/badges too.
Ah, no I meant the earlier multi spoke ones rather than the forged.
Part number is A120G0046F and £24 each! 50mm diameter, 13mm deep.
I do like the look of those black badges
Not wishing to shell out £100 for a set of 4, I made my own up at a fraction of the price, pretty happy with them, will be making up a black badge set also…
Nice! What’s the process?
Bit of trial and error to find the right caps to clip into the recess (Lotus ones are deeper than most), came in silver so sprayed black, resin logos bought online, all in all the set of 4 cost about same as 1 OE cap.
Can you give me a link to the matching caps, please?
Where can I find black batches?
Thanks!
Regards
Sven
I will PM you the links Sven…
Thanks a lot!
Parts ordered.
Regards
Sven
I’d love that link too…
BR
/Ragnar
Have sent you the links…
Hi Bryn, Sven and Ragnar, would one you mind sending me the link/details also.
I am down to one only and don’t appreciate the inflated Lotus tax here in Australia.
Thanks
Here are the links for anyone interested, though being on Ebay they may go out of date at some time…
The caps that fit are these:
http://www.ebay.co.uk/itm/151212964069? … EBIDX%3AIT
The badges are these, if you check the sellers shop, they also come in a black option
http://www.ebay.co.uk/itm/182028170380? … EBIDX%3AIT
Hi Bryn, thanks very much.
