I have a strange CL issue on my 2010 RGB. This morning when i opened the doors from the fob the passenger lock opened (silver plunger rose) but the drivers door didnt. i pulled the plunger manuall from inside, the door then opened. When i push the fob to lcok to doors both plungers drop, however when i try tp open i get the same again passenger door rises, drivesr door doesnt and i have to open it manually from inside.
Ill get the door pannel off later in the week and check supply to the actuator, but any other ideas?
Most likely the CL unit situated within the dash behind the light switches .
Try searching on here …there is quite a lot about it.
Gather its not too expensive io fix .
Good luck
Yes, mine packed up in similar circumstances a few months ago. Mine is an 07 car. With small hands the module can be replaced through the panel on the drivers side near the light switch, but if your car is 2010 then I’m not sure if the dash design is different. Part numbers are here, I think the module is about £80 and it was on back order with Lotus, but the manufacturers made another batch recently…
There are 2 part numbers:
A116M6048F - Prior to 08 MY
A132M0118F - From 08 MY
Prob best to double check on deroure in case they’ve updated part numbers
