Catch Tank
My S1 has a catch tank and breather kit fitted. (the invoice states that it is for the 340r?)
Does anyone know what it does?
Thanks
It collects the vapour from the cam cover - usually that gets recirculated back into the air box to be burnt.
So you will have a hose from the cam cover ( two pipes into one )to a ( most likely ) aluminium tank … which will eventually fill up will water ( condensation ) and oil …
The advange is when on track quite a bit of oil can find its way down the breather and instead of gumming up the airbox it goes to the tank
Thanks for that info.
How often should I look at emptying it?
Depends on the condition of your rings. I would check it after a track day to gauge how often you will have to drain it. Don’t be surprised if you find no real oil accumulation. If you have to drain it after a day at the track,you’ve got serious motor problems.
Interesting… anyone know where I can get one of these catch tank thingies ?
You could steal one off my new Exige, which is currently in a secure, secret location prior to being exported
[image]http://www.jsr.com/~dinks/Misc/George/Exiges/TiZige03.JPG[/image]
Looks like it’s already been nicked!
Just stealthily hidden behind the expansion tank (or so I hope )
The pipes on your are much more tidy.
Mine go over the middle of the boot (joke) and get in the way if you need some storage.
I’ve seen some photos of ones done like that before… I think some of the cars came factory like that?
Does anyone have the part number for that 340R two into 1 breather pipe???
If you can wait until tonight I have it at home!
Cheers mate, much appreciated!
Is the catch tank itself a Lotus part ?..If so can someone let me know the part number of that too ?
Cheers!
11t Catch Tank 13mm 340r A340E6011S
Breather Kit 340r A340X6013S
These are the part numbers printed on a receipt dated Aug 03.
Hope it’s of help.
Cheers matey!!
Indeed…Thanks !
Sean, have you managed to source the 2 in 1 pipe? If so where? I believe the Lotus breather kit is obsolete (ie no longer available)
No, not managed to get one yet. Still waiting on a call back from Lotus
Let me know how you get on. I’ve been looking for that kit for a while, but without success.
