can you help please?
i have an s2 exige 05 model, the problem is the heater blower has stopped working today i have checked the fuses and they are all fine, next week i am going to take the front clam off to inspect the heater box,
question …is the blower fault a common problem? and if so is there anything i need to check before i remove the clam? any help or advise will be much appreciated thank you. Sean.
Not sure if this applies - probably is the cause though.There is a resistor pack which regulates the fan speed which is a common fault on Elises.
See
my 05 exige has just been in for warranty work for a faulty fan blower,
all i know is that they had to remove the front clam to carry out the work.
HTH.
HTH.
Mine too, just before warranty expired
HTH.
SNAP!
Lotus must be cursing their blowers.
