Does anyone know the proper Camber / Toe-in settings for an Exige ?
David,Standard settings are:-Frontcastor +3.8 +/-0.2; max side/side 0.2camber -0.5; +0.1, -0.2; max side/side 0.2Alignment 0.1mm toe out overall; +0.1mm, -0Rearcamber -2.4; +/- 0.2; max side/side 0.2alignment 1.2mm toe in each side; +0.2mm -0 max side/side 0.2mm[This message has been edited by Phil Davies (edited 14 August 2002).]
Many thanks Phil, that’s going into the “Stuff you need to know” section.
