hi all just a quick question, whenever i pull away from the lights quit fast i get a funny burning smell,[im not wheel spinning it either] just wondered wha tit was and if any of you suffer from the same thing? it only happens in 1st gear.many thanks for any replies.
Possibly the connection between engine and driving wheels … er the clutch ??
how can i slove the problem with the clutch?
quote:Originally posted by kieron:how can i slove the problem with the clutch?The problem isn’t with the clutch… [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image]
then what is the problem then steve??
quote:Originally posted by kieron:then what is the problem then steve??If the Elise follows the same layout as the Exige, you should be able to locate a manualy adjustable throttle device at the right hand side of the drivers footwell. This may require less pressure when engaging forward motion. [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image]
yes but if i put less pressure on the gas then i will start to get beaten by milk floats!
quote:Originally posted by kieron: i will start to get beaten by milk floats!Only if it’s Ernie…Pesky will explain [image]http://www.exiges.com/ubb/NonCGI/images/icons/grin.gif[/image] [image]http://www.exiges.com/ubb/NonCGI/images/icons/grin.gif[/image]
I’ve seen (very briefly) the odd barge on track, but never a milk float [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image]
