Car runs great. But recently (past 25miles or so) there’s a smell coming from the engine compartment. Oil is good (recent change and level ok). Did a compression check and the cylinders read 250 psi across the board. Any thoughts? What are you guys getting for your compression tests?
It’ll be an oil leak rather than an engine problem I expect, Check around the oil filter housing for any leaks from the oil cooler unions/ oil pressure sender.
250PSI evenly across the board is fine.
Dave
I had a hairline crack in my oil filter housing-had to fit a new one.
I had one of those in the early days, swapped under warranty luckily as I think is was a �250 part.
