friend of mine had the engine let go during a race last year. the car’s been sitting under a cover until the last few days and suddenly it’s time to get it going again. very initial check says zero pressure in cylinder 3 but the others are ok. not known at this stage whether there is head damage due to possibly broken piston. owner thinking of a rebuild, and bigger power: 300+ to run in local GT series.
suggestions as to :
rebuild: pistons, s/c setup, map, etc.
drivetrain especially gearbox: seems a quaife sequential is not as expensive as it used to be.
this would be a good start, if you are keeping with the MP62 SC don’t use too lower compression pistons with a 2.6" pulley and a decent charge cooler you should see 350hp+
Wisdom seems to be that there isn’t enough material between the bore to go oversize. You might be able to machine and sleeve to standard size. Working through options for a build myself so interested in what you decide to do.
