Brakes
[quote=6970K]Pagids here too.
Had PF previously which were fine only the deposits knacker the finish on the wheels
…if used for the first time in the wet only I’ve found tho. I use PF’s, SRF with 4’s and braided hose’s and my brakes are AWESOME! :slight_smile:
Yeah Jonny if you leave the deposits on the wet gooses the finish.
I seem to recall someone at one of the Exiges trackdays cleaning the wheels after each run. Maybe Benja when he had the white wheels :smiley:
Not me, I’d given up by then. I think it was Princess Con :wink:
[quote=jonnyfox][quote=6970K]Pagids here too.
…if used for the first time in the wet only I’ve found tho. I use PF’s, SRF with 4’s and braided hose’s and my brakes are AWESOME! :slight_smile: [/quote]
copycat !!! :smiley:
No once that first blast is over I’ve never had a problem…not need to clean during a TD, even a wet one. I’ve done loads with these pads it’s just the very first…
