Noticed yesterday when cornering at speed (50-60) I sometimes get the brake tell tale flickering on ? any ideas ?
Brake fluid level warning light!!!
level is fine ?
Under hard cornering the fluid surges and ‘can sometimes’ cause the light to flicker.
Not saying it defo is that just that it could be
Hope it helps
Agree with Dave. Also check that the fluid plunger/sensor is moving freely & not sticking.
Could also be a loose handbrake lever (happend to me once).
Pads are probably low.
As above this is usually the fluid. Always had to slightly overfilled mine.
Handbrake sensor. Bang the handbrake down. If that doesn’t make it go out then take the console off and bend the arm of the microswitch
