Is the juddering I experienced on my last track day using stadard Exige S1 brakes/pads probably due to the pads overheating?
If I want to upgrade to Pagids, what is the difference between RS14 and RS42’s, and for me as primary road use with occasional track use, which is the better?
Sounds like you’ve overheated them and now you’ve got uneven pad deposit on the disc. You didn’t leave the handbrake on after you came back to the pits did you? That’ll cause brake judder.
FWIW, I use RS14s on the road and have never found them lacking at all, other than being a bit noisy when they glaze over from lack of hard use… yet to find any fade with them on track use in NZ summer heat. TBH I’d not find a need to go to RS42s on the road, I find the 14s so damned good
I understand the Lotus bedding in process is to get them hot/soft by half a dozen hard stops from high speed. Then stand as hard as you can on the pedal for a couple of mins.
Does anyone else get the horrendous screeching from RS14’s when they are new and bedding in? This is on Geary’s ali belled disks.
Completely natural… had the same thing for about 2-3 weeks with my RS14s on EBC discs (same as Geary’s but without the Ally bell)… quietened down after that once they’d had a few heat cycles in them.
TBH noisy brakes don’t bother me one bit… in a daily driver they might, but on a wekeend toy it’s a nice change actually
I agree they do make a noise and need using hard to get rid of the squeal, but that can be temporary and it can return again on the same set of pads until you use them hard again.
