Brake Fluid
Is there a reason why people don’t change to silicon brake fluid? As far as I can see it has a number of advantages
1 It does not absorb moisture, so never needs changing
2 It has a boiling point of 500F (260C)
3 Its non-toxic or corrosive… so I can drink it or rub it all over my body
Is the price its only negative point 1 ltr about �20?
NO
Silicon Fluid is bad news:
  1. It does not mix at all with water but water will still find its way into the brake lines ( condensation etc ) and instead of being absorbed and a gradual degarding of the boiling point you may get a water drop in the caliper and that can create a vapour lock and hey presto no brakes ( so uning Silicon fluid for tracking is not a good plan … )
  2. The water not being absorbed will sink, being heavier than the fluid and corrode steel pistons etc - so you still need to change fluid to purge the water
  3. Its incomaptible with DOT 3, 4 and 5.1 so you have to flush the system very well
  4. It tends to grab on to “muck” and thus can clog up the small drillings in the caplier - so you need to change fluid again anyhow
  5. There have been reports of some type of seals being affected by silicon and “balloning” - so you loose the seal and so your brakes.
Enough reasons
Thanks Andy, that answers that then…
looks like I will stick to rubbing it on my body ( will need more than 1 litre though )
Andy
Thinking about what you said, this could explain some of the issues I have with the brakes on our Esprit ( had silicon fluid in this when I bought it )
Yeah - forgot to mention spongy pedal is also difficult to get rid of becuase of water droplets rather than absorbtion.
And it reacts badly with some rubber seals and swells them.
The spongy feeling, even from fresh is one thing I’ve often heard.
Super DOT 4 is the best (Castrol RS is beter but overkill)
(off to hide, Pesky will be back soon)
PMSL!!!
Not for a while, the old bugger is off on holiday, getting his new teeth and hip replacement done in foreign climes.
I can see you
I can see you
Oooooh, had your cataracts done too?
No he has had cataract transplants - he now sports cataracts from a Pippistrelle Bat
I can see you
You must have landed one of them there dead posh hotels with tinternet access.
