Brake Bleeders
I wanted to purchase a manual brake bleeder kit, but since I am in the USA, I can’t get any advice from the vendor what size fitting I need to fit over the reservoir.What size is it? What brake bleeder kits do 'yall use?
quote:Originally posted by beto:What size is it? What brake bleeder kits do 'yall use?I use Colin from Columbia Motors [image]http://www.exiges.com/ubb/NonCGI/images/icons/wink.gif[/image][This message has been edited by RussT (edited 21 October 2002).]
I use the Gunsons Eezibleed, it comes with various caps to fit the reservoirs.
quote:Originally posted by Phil Davies:I use the Gunsons Eezibleed, it comes with various caps to fit the reservoirs.Can you measure the cap you used with your Exige? Pretty please?
Ok will do when i get home, IIRC its the plastic cap i use, but then you have to choose which rubber washer is also needed, the Eezibleed is available in the US abt $34 on a quick Google search [image]http://www.exiges.com/ubb/NonCGI/images/icons/smile.gif[/image]
Phil,I surfed around the eezibleed dealer sites, and sure enough there is goodness in the product. I assume the standard kit comes with the right cap - I saw there were additional caps available for another $9.99…I bypassed that. Thanks for your help.Bob
Perhaps you already got a different one, but I like this one a lot (better than the EZ-bleed): Motive BleederIt’s bigger (holds up to 2 quarts) and doesn’t need a spare tyre for the pressure.Bye, Arno.
