Hey guys,I had my boot lid re-aligned on my Exige S as it was rubbing the passenger side surround. The boot was perfect but now it has developed a problem, it wont close like normal?
Everything looks fine but it just wont click shut like it used too, anyone had this issue or know of something that would be causing it?, its aligned perfectly but it just wont click shut, just bounces.
cheers
Had this on my exige and presume its the same: there is an arrow type bolt surrounded by the spring on the underside of the lid, if this turns 90 degrees it wont shut as its in the wrong direction just needs turning quarter turn. HTH
Blimey, where you been hiding!
Hi Tony, yes i’m still around! Still read the posts on here and on PH just don’t bother with Seloc anymore as i said “too many dickheads on that site now”. Car still running fine although i do need some new discs and pads which i’ll get Ian to do soon. Hope you are well
All good here (at least no more trips to Specialised at the moment!)
Cheers guys, I went out and had a look again after i posted and the spring was loose. Now fixed
