Hi all.
I am doing a bit of a refresh at the mo. What boost clamps are you running on your s2 exige with S?
What is the OD of the pipework? Mine is in the garage and I am warm in my office …
Hi all.
Murray Constant Tension Turbo Seal Clamp × 8
64-86mm
Perfect! Thank you
No Prob, alternatively you could look at a ‘t-bolt’ style which will likely hold more torque - but generally I find these too wide to comfortably fit in the recesses of the OEM boost pipes so can’t apply their clamping force as well.
Like the type used here: https://www.waltonmotorsport.com/product/radium-engineering-intercooler-coupler-kit-lotus-exige-s-2zz-ge/
Radium.
Shall investigate!
Yes with the silicone hoses. I keep looking for second hand
Just buy direct from Radium.
They are very easy to deal with.
Or dont bother…
The Exige S2 has low boost and doesn’t need uprated clamps.
Unless its for the ‘bling’ factor obviously
Mine are just adding lightness ( rust ) so wanted a replacement set for aesthetics.
