I have the same SCRP as Mark A but with a Powerspeed rear box.
The Powerspeed is repackable but I havent had to yet in 10K miles of mostly track use, it is a relative large box but I have never had a problem with noise - its deep and not “tinny” which I like
Cheers guys. Yeah the Elise parts SCRP tthat I have currently is a round 4" silencer, I wonder why they changed from the original design that you have?
I will see how I get on with the new SCRP that they are going to send me. But if I still have problems then the rear silencer will have to be changed.
What exhaust manifolds do you guys use??? Mind you I guess the diferance the manifold would make to the noise level would be minimal?
I was surprised when I saw one of the new Eliseparts SCRP on someones car at Goodwood in November, when I say on the car, it was actually being replaced by a Cat as he had failed the noise test.
Sean B - a 4" scrp doesn’t leave much volume for silencing if you’re using the correct dia perf tube (2.5"o/d ). I know some bring down that dia some to 2.25". Certainly Mark-A’s oval has a larger volume but it’s not re-packable.Come to think of it,I’ve never seen a re-packable scrp! IMO a sports cat is best - a good silencer, no loss in power and no re-packing issues.
One thing is puzzling me tho, how come most (some?) of the Caterhams pass the noise tests with comparable size silencers + bore and in some cases with more power?
