I have a 2006 S2 S with the 260 upgrade, standard exhaust and airbox. Am thinking about the LoT day at Bedford in November, but wandering whether the noise factor will make it a very brief day!
Static was measured at 92 db at Brands, but I gather it’s the drive by reading which is the problem for supercharged cars (87.5 db limit). I had the TRD airbox swapped out for the OE version but I can’t say it’s a whole lot quieter. The snorkel is definitely fitted.
Has anyone else with this config had problems at Bedford or will I be ok?
Fingers crossed for you. I’ve got a 3bular and I daren’t go near the place. They black flag me on the first session at Brands and Bedford is even less tolerant I hear.
Luckily I have a switchable end tip to a larger silencer, so I can keep going but even with that I have to keep the revs below 7,000. So sadly it can never risk Bedford.
Hopefully the standard exhaust will make the difference, but I’ll stay away from the redline! 3bular must be pretty loud. Guy with an Evora was black flagged at the LoT Brands evening last month for noise, not sure which exhaust he was running. Didn’t seem as loud as some of the other cars there.
No problems for my S240 running a standard exhaust and TRD airbox at Bedford or Brands Hatch.
I did briefly run a 2bular GT3 (or 3bular as it’s now been rebranded ) at Brands and got black flagged when giving it the beans. It also sounded terrible, but that’s another story!
Difficult to understand why, but yes that does seem to be the case. You’d think db was db and wouldn’t be dependent on frequency. Maybe it’s the case that the meters do in fact have flat response but our ears perceive certain frequencies to be louder i.e. V8’s!
I got a clip extension to my 2bular (specced it when I ordered it) so that helps reduce the noise a bit - still have to lift and not really go over 7,000rpm though at Brands.
But the fact it allows me to make a physical change to the exhaust from the regular tip when that gets black flagged allows me to carry on the day.
But overall, Brands is so strict now. Other circuits seem ok and I’ve not had to clip this on.
So all was well in the end. Although I was black flagged for noise, told to report to the office, but it turns out the culprit was a V6 that I was mistaken for lolz. No further issues!
It’s a long lap isn’t it! Instruction in the afternoon helped a lot.
Starting to think about harnesses, but that will involve swapping the seats etc. Need to do a bit of saving first I think!
