Ive been having a few problems with my battery not holding its charge, it turns out that the positive battery connector is well and truly corroded and being an ‘anorak’ I wanted to replace it with an identical connector…no bloody chance! As you know the S1 has a simple battery connector, so simple I cant get one anywhere!
Actually thats not true, Lotus will sell me one but only if I buy the wiring loom as well, no suprise there then!
By corroded I assume you mean more than just sulphated up. If they were sulphated then you could just wire brush it clean again.
So if its corroded to the extent that metal is missing then before replacing it I would be concerned about what caused such an abnormal occurance.
I agree with Steve,but also there may have been some impurity in the connector although unlikely.I would expect its a pretty standard part and most auto factors wouldnt really be bothered trying to source one for you.Try taking what`s left of your original and trawl a few breakers to find a match,dont forget your wire cutters.
Sorry no help on replacing it.
Yes, its corroded to such an extent that there actual metal missing!
I thought about contacting that geezer who had his Exige written off by the valeter, bet hes got a spare one…among other things!!!
Yeah thanks for that, ive already been onto them but they dont have anything that resembles the corroded one…in fact I cant believe the Exige actually leaves the factory with such crap connectors…have a look at all of your Exige connectors and you’ll see what I mean…no expense spent on them then!
Just bought a new Bosch Silver…standard size though… yet it was still a b@stard to remove…thought id better check the manual first…what a waste of time that was, it didnt say you had to remove the radiator shroud etc.
I’ll probably end up modifying the loom and fitting some high quality connectors!
salvage yard,or if you want to be posh,try demon tweeks.At the end of the day its only a connection.stick a jubilee clip around,brade the wire around the terminal then tighten gently.That will work till you you find what you want
Probably your best move tbh…
It sounds like the missing metal may actually have been caused by arcing. It’s unusual for galvanic corrosion (dissimilar metals) to take hold to that effect. Although not greasing the terminals will accelerate the process.
Anyway - have fun. Watch the old belt buckle on the front wing! Best lay an old towel over the wing first!
Yes the terminals were dry as a bone, no grease at all…as for the ‘belt buckle’, ive actually got a mechanics wing protector that I use to prevent scratches!
