Dave - sounds plausible although in a closed system such as an engine, if there’s no oil in the sump at higher revs - where has it gone? The speed of the oil up into the engine vs the speed of it returning under gravity can only really be balanced by the absolute volume.
Maybe instead of or before baffling sumps we should just have larger capacity ones - therefore having more “reserve” for the surge moments.
[quote=stevegreen]
Maybe instead of or before baffling sumps we should just have larger capacity ones - therefore having more “reserve” for the surge moments. [/quote]
And then catch it all in bloody catch cans …hahaha
Cheers Will [/quote]
Additional fore and aft baffling.
the gPan is on special offer as I have a couple left. the actual true diff is �25.00
Discount, I heard that pardon, who said that…
Discount, I heard that pardon, who said that… [/quote]
So how do I order a gPan can only see the gpan 2 on your site
make sure you order some flexible sealant and have a tool to get the old sucker off.
I used a window putty palate knife banged in flush. Once you’re in it then goes around easily
sector 111 stuff does come with a very good instruction sheet
[quote=661]make sure you order some flexible sealant and have a tool to get the old sucker off.
sector 111 stuff does come with a very good instruction sheet[/quote]
I’m pretty inept when it comes to spannering, so it’s going to be fitted at the same time that the car is serviced by someone who (hopefully) knows what they are doing.
William
Where did you have in mind? JS Racing are only a short drive up the M40[/quote]
It’s got to go to castle to have a door lock looked at under warranty (key doesn’t seem to fit the barrel) and they are going to do it at the same time together with a service. I have looked at where JS Racing is, but google maps reckons its 2 hours each way, which seems a bit much!
Toyota sealant is the real deal, but at �80 for a tube, which probably has enough sealant for several pans, I used the sector 111 recommended sealant, about �12. It’s on here somewhere on an old thread if anyone wants the name.
