Hi, up for sale a setup perfect to put into a Lotus. Just removed this from a running Audi powered S1 Exige for a big BHP upgrade so know its fine.
You will get;
A 1.8T 20V Engine that has the 225 stronger BAM bottom end but using the large port AGU head. It already has a baffled sump and comes with the bigger K04 Turbo so plenty of scope for additional power.
Full custom built 2.5 inch exhaust system that bolts straight to the Audi engine and mounts straight into the S1 Lotus chassis using the standard mounting points. Complete with CAT.
A Pro Alloy intercooler designed for the Lotus and complete with large Spal fan.
All the boost hoses to link the engine to intercooler and then to the inlet.
It does not come with engine mounts.
For full asking price you will also get a Pro Alloy modded inlet manifold for the Lotus install. There is a fuel rail and injectors included as well.
Perfect for someone thinking of doing an Audi conversion. Add some mounts from pupa smerf, wiring, ECU, cheap Audi gearbox, plumbing and few other odds and sods and you have a 280bhp Lotus!
Any question on parts or installation just shout!
£1000
Stu
